Engine/Transmission (1998.5 - 2002) low rpm sputter or hesitation!
2nd Gen Non-Engine/Transmission Factory alarm does not alarm.
hi, my 2001 auto 5. 9 has a low rpm sputter or hesitation,this is right when i try to move,the engine will hesitate and fail to rev temporily, i have tried all obvious things like fuel filter etc. it goes away after around 1500 rpms and its worst when she`s cold ,any thoughts? thanks
I had the same problem with my 2001 with 5 speed. It got progressively worse and
soon was hard starting. Last week we replaced the vp-44 pump and the problem was
solved
Any codes being captured by the PCM/ECM? A bad or out of calibration APPS could cause this as well as a bad VP-44. Check to see if your system has any codes latched.
Thanks, if it is my vp44, how big of a job is it to put the p pump on it? i have several 5. 9 cummins industrial engines with the inline pumps on them,would the conversion be difficult? i guess the computer would be a problem huh?
