WBerry,
Even though you increased fuel rate the govenor still controls max RPM.
But the real question what were your base numbers before adding the goodies from Banks. RPM,boost
Another words was your max RPM 2300 to 2400and where was your max boost 25.
High idle screw, can be adjusted for max RPM.
You mite have to get one of those adjustment elbows on the turbo. It wil let you pick you own max boost.
Changing your afc springs in Govenor will help to achieve desired max RPM also.
Also a wastegate solenoid pre-set to one boost setting.
