You're on the right track...
You'll have to swap out your drop axles for straight tube type. EXCEPT the straight tube type has camber built in to it, so you'll have to spec them out for the spring pads to be on top.
Should be around $400 each for 3500lb axles with electric brakes- more weight, more money.
