I developed a low speed growl/rumble on my 06' Mega. Below 15mph it feels like I'm driving on Super Swampers. I normally have 19. 5's on the truck. I swapped the stock tires back on. No difference. I also just put on a new passenger side unit bearing. Swapped the stock unit bearing back on to the truck. No difference. Also pulled the front driveshaft. Still rumbling at low speed. Pulled front/rear diff plugs. No metal. Gear oil looked great. Had my wife drive the truck past me at low speed in a parking lot. Nothing obvious from outside the vehicle. I've had the steering box brace for 2-3yrs. Rear driveline looks ok. Front axle shaft Ujoints also look ok.
Can bad shocks cause a growl/rumble? Can the steering linkage cause a problem at low speed only?
