Low Sulfer ECD fuel in California
Last Day to Order 2002?
Fuel Filter change every 12K is that often enough?
This stuff has got to be bad. I saw it today in an AM/PM mart. Twentynine palms,CA. Said Low sulfer, emission control diesel. What is this stuff? I didn't put it in the truck. Will it hurt injection pump?... ... ... Is it for a trial or is it for good?:mad: :mad: :mad:
Low sulphur feedback...
Greg, low sulphur diesel is a step towards making diesel fuel a little more environmentally friendly. I've been using this stuff in my truck ever since I got back to Europe almost 12 months ago now and the truck hasn't missed a beat so far and it is still running strong plus the ol' VP44 seems pretty happy too (22k miles/35k kilometers and counting... . )
We don't have the ECD "green" label though. Hmmm, it might be worth while finding out what the "deltas" are (how many ppm) between #1 and #2 "regular" diesel fuel in your part of the world and then make a direct comparison with the new stuff, to make an informed assessment.
Sulphur is @ 100 ppm here...
I can second what JohnMcIntyre says.
My truck runs on the low sulphur stuff from the beginning.
No problems at all.
Marco
I believe that the Arco stuff is 15 ppm, which is the target nationwide for 2007. Ultra low sulfur fuel is a win-win situation. The process used to reduce the sulfur to hydrogen sulfide gas also removes the aromatic compounds in the fuel. Aromatics have lower energy content per mass than the paraffinic molecules that remain after treatment. Thus, the centane number of the remaining fuel increases as a result. Aromatic compounds contribute to the lubricity of the fuel and there was a problem in Europe many years ago when they first started to reduce sulfur (and aromatic compounds). But the lubricity can be restored by adding back a small amount of relatively inexpensive additives such as fatty acid esters. Diesel fuels available in just about any place in the world except North America have lower sulfur and higher cetane than our diesel. Engine durability is no longer a problem. Some forms of biodiesel have almost no sulfur content and they seem to work fine.
Actually, an engine has to be tuned properly in order to take full advantage of a high cetane fuel. This is largely a matter of injection timing. Our Cummin’s are designed to run on pretty crappy fuel. So other than less noise and smoke on startup and potentially longer oil change intervals, there is not much of an advantage to running low sulfur, high cetane diesel. Except for cleaner air of course. But once the new fuel is generally available by 2007, newly designed engines will be able to realize the performance advantage.
low sulfur fuel
I don't know about newer engines, but when low sulfur fuel was first introduced about ten years ago in California we had a rash of fuel pump failures in our Cummins 855 series commercial engines. I believe the final analysis was that the sudden change from high to low sulphur somehow caused a problem with the seals in the pump which led to the failures.
After the rash of failures things settled down and we have few fuel pump problems with the current generation of engines.
Will the change from low sulfur to ultra low sulfur cause similar problems? Time will tell.
Ultra low sulphur fuel
The VP in our trucks can also operate on that stuff. I'm using it several times. Only downside seems to be that good part of the smoke disappears...
BTW. Our low sulphur fuel DOES produce more hp than your stuff!
While developing our touys, Andy @ ADT has always noticed 2 Psi less top boost than I got. Andy's engine was set up EXACTLY like mine. Or was it mine exactly like his? Dunno can't remember. :D
Marco
