Howdy folks,
Long time member, but don't get on here much any more just too busy, and the old truck just keeps going and going with very few problems. I got a new job last April that requires me to commute about 60 miles each way. My old truck that has been my trusty steed in my construction business since I bought it in 2000 was pressed into the daily commute, until I could see if the new job was going to work out. I was planning on buying some kind of rice burner after I got into my new job about 6 months or so which would be around Oct 1st. In which case I had planned to get her all detailed out and fluids changed and put her in the garage, and only use her for the occasional trip to the home improvement warehouse.
Anyway, on my way to the office Tuesday morning, my check gauges light came on and the voltage gauge was low and in the red, the other gauges were normal and the water temp OK, I thought maybe the belt had broke, but that was not the case. I originally thought of the alternator, and removed it and left my truck at work and borrowed my boss's vehicle to take home for the night. I stopped at a local O'Reilly's for a reman alternator, the counter person said we should check my old one 1st and it checked good. Confused, I returned the next day, re-installed the old alternator and the truck would not start, because the batteries were discharged, so we put a battery charger on it all afternoon. I was able to drive it back home on battery power alone, I have tried to have the batteries load tested but the tester just said, 'Undercharged'. I have it on the battery charger again at home now, so I will have the batteries tested this weekend.
I have checked the fuse box under the hood and everything seems OK, and have searched the web, so now I have more questions than answers.
1. Crankshaft sensor, I have read that if it goes bad the PCM won't tell the alternator to charge, but if it was bad wouldn't it trigger the CHECK ENGINE light?
2. Battery tray sensor, How can I test it to see if it's bad?
3. Voltage regulator in PCM, again if this fails wouldn't it trigger the CHECK ENGINE light, because mine is off. Also, there are rebuilt computers on ebay and the web for less than $200, are these quality units, has anyone ever tried one and from where? Does Mopar offer a Reman PCM? I could call the dealer but don't have my VIN with me right now.
4. I know it's way cheaper, but somehow just seems cheesy to do the 'External Regulator' thing. But seeing how I only need my truck to really get me through the next 2-3 months is probably what I will do.
I would like some advice on where to start diagnosing things, and how I can be certain it indeed is the PCM that's bad. I am going to most likely just replace the crank sensor and see if that helps, then go from there.
My father in law has a somewhat OK scanner, and on most vehicles it gives streaming data, but on my truck it will only read codes, the only code I had was po1692 (I think) 'system voltage low' when we tried to see the streaming data it said 'Cannot communicate with ECM' is this bad news, or is it just because it's a diesel and the data stream is different somehow?
I have found bits and pieces to this puzzle if someone could direct me to a good troubleshooting article somewhere it would be greatly appreciated, I do have the Haynes manual but do not have the factory service manual, yet.
Thanks for the help in advance. Sorry for the long post.
98. 5 Regular Cab, Laramie SLT, 4x4, 5-speed, 3. 55's, 275 Bosch Marine injectors, 4" turbo back exhaust, 375,000 miles, DRP lift pump on frame, Van AAiken box (until it crapped out last year does anybody have another one? cheap?)
