I'm experiencing a low vacuum problem that I've isolated to the control switch on the transfer case. When I disconnect the vacuum line going to the transfer case my vacuum holds steady when I shut the engine off. When it's connected my vacuum drops immediately. So, I assume that is where my problem is. My question is, if I disconnect this vacuum line, will it bother any other operations other than four wheel drive or does it give me too much vacuum? Thanks for your input.
