I had a problem last weekend that the batteries went dead after sitting for one full day, it was cool, about 50 degrees out, I figured one of the batteries went bad, so replaced them both (they were only 8 months old, so got a new set for free), the volt meter had only showed low volt once before, after a long run (20 hours nonstop) and sitting two days, but started that time, and showed 14 volts after 10-15 seconds. After replacing the batteries it looked ok for a day or to, mostly daytime hiway driving, but now it is only showing maybe 12 volts going down the hiway, once in a while it will creep back up to 14 then slump back to 12, not the sharp change like when the grid heaters are cycling. wondering if maybe my alternator is going, or if i got a bad batt. will try to have the batts and alt load tested. Hooked the batteriesto a charger, still in the truck and hooked up, only drew 5 amps (charging both at once) for a few hours then down to 1 amp, where it stays, so apparently the batteries are charged... any ideas? it is a possibility that the alt. has been compromised, it has been sprayed with plenty of engine oil from leaky breather before i moved it, and later by coolant from leaky head gasket.
thanks for any thoughts.
