Is it possible to remove (and replace) the passenger side lower ball joint without removing the hub assembly, bearing and axel? I have a small amount of play in just the lower ball joint which I discovered using a pry bar under the tire with the truck jacked up about 2" off the ground. Any advice appreciated.
