Lower control arm cam bolt?
Looking for Cooper STT's
Bed Divider
I replaced my control arm bushings yesterday and couldn't remember were the cam bolt on the lower control arm is supposed to point. I have a Skyjacker 3" lift, so stock upper and aftermarket lower arms. Does anyone know? Thanks
The lift will reduce caster and with 3" I would dial in max caster which means you want to rotate the differential cover "up".
Putting the cam bolts in so the washer has the fat part facing the bumper is the most you can do.
OK, thats where I have them, just didn't pay attention when I took them out. I did notice the axle rotated, just wasn't sure if it was for castor on the wheels or to adjust the pinion angle. Thanks
PS. Glad I got them right;)
