Had to install a new lift pump. Had to do it in the garage and buy the pump, even though warranty would have covered it... I didn't want to hassle with towing. Long story short, I had it in Schied the day before to troubleshoot the now new crank position sensor. They were going to do a fuel pump check the next day, but I decided to change the fuel filter the night before. It wouldnt prime at all. The LP wouldn't fill the cannister after I even removed one of the brass plugs from the top aluminum housing. So I just bought and installed it myself.
Only thing was though, when I got it on, the pump only filled up the cannister after totally removing the brass plug completely. When I took it off, the pump finally sounded like it was under load and the tone got louder like it was pumping liquid and not air (Free spinning). I suppose this is how it works. But I figured once all the air was out it would sound like it was under load and pumping fuel... back to the tank and all.
Well, I cranked the truck for about 5-7 seconds and it started, and ran fine without a flutter which is light years ahead of where I was yesterday.
My question is, once the system is completely purged of air, should the pump sound "loud" or loaded constantly when I bump the key and let it run for 30 sec. Right now, when I bump the starter, the pump just sounds like a little quiet electric motor, without that loud humming I got when it finally picked up fuel. It sounds just like my "dead" one did when it would not prime the system. I am worried I got a new unit that is also bad. Do new ones go bad right off the shelf. Scheid said it was the latest revision available. Thanks.
