Engine/Transmission (1998.5 - 2002) LP pressure fluxuations at idle, ok at wot?
2nd Gen Non-Engine/Transmission 241LD to HD swap??
Engine/Transmission (1998.5 - 2002) Question about the MAD ECM
:( 3rd lift pump is going at under 1000k on it. Anyways, this one is dying a little differently. I get big fluxuations at idle(3psi to 14 psi), once on the throttle it acts fine... I assume because once vp demands the fuel it's vacuum is helping out?? No underlying problems here I hope, let me know if anyone thinks otherwise
Thanks
Steve
Same here, just like you describe.
The problem turned out to be a bad overflow / pressure regulator / whatever valve in the VP-44.
Got another one and problem solved.
I didnt even bother too disassemble it just glad the problem is fixed.
