I am 90% sure my LP is about done (345k it has been a good run). The primer button on the pump never worked so years ago I put a elect pump in the line at the tank just a small 7 psi one (this is nice).
A month ago truck started running poor so I changed the fuel filter and then turned on the key to prime the filter and nothing so checked out my elect pump and it was dead, so i replaced it and everything was ok.
The other day i checked my fuel pressure and found it to be low 18 at idle and 28 at 2000 so I checked overflow valve and found it to be a touch over 1/2" so I streched a touch to see if it would help and the reading came up to 20 and 30 still lower than should be remembering I have 7psi pre pressure I am sure the LP is about done.
I have read that you change the o-rings but will this help pressure or just a leak repair?
Where is the best placeto purchase new Lp Is there a hose issue with the new pumps being in the wrong place.
Thanks
Joe
Thanks
Joe
