This should be an easy one. When my truck is running, I see anywhere from 15 to 17 psi on the lift pump pressure at idle. WOT under load never sees below 14psi. Maybe I got a good one when I bought this one.
When I first turn on the ignition without starting, the LP runs for about 3 to 5 seconds, the pressure goes up to 15 psi. Then the LP stops and the pressure starts dropping to basically 0 again, until I start the truck, at which point it goes right back up to 15psi.
Is the system supposed to retain any pressure at all. I mean when the lift pump runs for a few seconds when I turn on the ignition switch, should it drop to say 5psi and hold until I start the truck. Just wondering if its normal to drop down to 0 psi again.
I didn't put on new banjo washers on when I installed the new LP. Schied didn't tell me I'd need any. And I couldn't wait another day for them. The old ones looked fine. And It doesn't leak. I was just curious as to where my pressure is going... unless its going right back to the tank.
