The lift pump voltage is controlled by the ECM (Engine Control Module) mounted on the driver’s side of the engine. It will reduce the lift pump output pressure when starting by quickly turning on and off the 12 volts to the lift pump. This causes the lift pump motor to rotate slower and will reduce the fuel pressure to the injection pump to about 7 psi. After the engine starts, the ECM will apply a constant 12 volts to the lift pump and cause it to run at full speed for as long as the engine is running. The lift pump pressure, running at full speed, is limited to about 15 psi by a built in regulator valve that will re-circulate fuel from the pump output to the pump input. This re-circulated fuel passes through the motor assembly and is used to lube the motor bearings and cool the electric motor. As the pressure gets close to 15 psi, a spring in the regulator valve will compress and allow a ball valve to “spill back” the excessive pressure. In my opinion, it will also cause the fuel to pick up particles of graphite from the motor brushes and metallic particles from the motor commutator and bearings. Hopefully the filter will catch all the junk generated from the pump.
