Turn key to "on", I get the short (1/4 sec?) burst on the lift pump. Start engine, I have ~18 psi. After idling for a minute, or so, the lift pump shuts off. Turn engine off, wait 30 seconds, and lift pump is "working" again - for another minute.
I don't think I've seen this as a symptom of a dead LP. I do have a brand new one sitting on a shelf, and it's easy to replace, but I thought I'd first ask if anybody has had a similar problem, and if replacing the LP fixed it.
I can also reproduce the non-running-LP symptom by cycling the key from off to on and back a few times. The first couple of times, I'll get the short burst. After that, it's dead until I let it "rest" for 30 seconds or so.
EDIT: One thing I have noticed... for the last couple of days, my idling FP has been about 18 psi. It used to be about 14. This change seems to correspond with the installation of the Comp. Could the added fueling demands of the Comp have killed the [original] LP?
