Engine/Transmission (1998.5 - 2002) Lp + Vp 44 #4
Engine/Transmission (1998.5 - 2002) 241 transfer case
2nd Gen Non-Engine/Transmission Sunglass Holder
Well I am now the proud owner of a fourth lift pump and VP44 (stock + 3 replacements). :mad:
Because I am at 99950 miles, I decided it was time for a more permanent fix. So I had ATS install a F. A. S. S. pump to push fuel through my shinny new VP44. I want to say it made a big difference in the performance of the truck, but that might be the difference between a working pump and a dead one. :rolleyes:
Thanks to the ATS folks, my truck works again. Oo. I just wish Dodge would pay the price of the F. A. S. S. pump instead of giving me more pumps that will die in 25,000 miles.
Scott
that's great to hear! I have a FASS pump only on the way right now. Did you get the whole setup or just the pump only. What kind of pressure are you seeing, idle and WOT@3000RPM?
JC
Dang Scott, I was pe'od at being on my 3rd vp. The last one was on my dime no more warranty for me. I just put a RASP pump on before my 2nd one went out but it had already started acting up before I put the new RASP on. Hopefully the 3rd vp will last longer than the first two. I got right about 70k out of each of the first two. Much better than your 30k. Replacing them on your dime will sure put a dent in your wallet.
JC,
I got the pump only. I'm in school right now (read: I have no money), so that seemed like a good call. I get 19psi. The needle never moves. From start to red line: 19psi. :cool: :D I kind of like seeing that needle NOT move. Especially after seeing all of the 0 psi before. #@$%! :{
Barry,
I'm really hoping to avoid replacing the VP on my own dime. That's a lot of dimes. :{ How do you like the RASP?
Scott
