Lubing calipers
Bombers to 4000 rpm, any cam failures?
First oil change
I had read a post about sticking brake calipers and someone mentioned that they lube their calipers, how and were is this done as I think I have a caliper hangging up because the truck has a constant pull to the left and when I apply the brakes it really pulls to the left and when I pull it apart I want to hopefully cure it.
Paul
'96 2500 ext. cab, LB, 4x4, 5 speed, 3. 54, TST 280 cam plate, AFC spring kit ,pyro and boost gauges mounted on A-Pillar, tinted windows, 16x8 Eagle alloys series 1219, 285/75R16 Durango A/T's
See this post - https://www.turbodieselregister.com/ubb//Forum17/HTML/000468.html . Near the bottom I say what I do to lube my calipers.
-Steve St. Laurent - President of the Great Lakes TDR, Chapter Forums Moderator
'98 QC LB (CMNSPWR), 4x4, ISB, 5sp, 4. 10 LSD, Prime-loc, SW fuel pressure gauge, boost & pyro gauges, TST Powermax, muffler eliminator, polished valve cover, BD exhaust brake, Isspro turbo temp monitor, Mag Hy-tec rear diff cover, Permatech liner, Grizzly SS nerf bars, Stull SS grill & bumper inserts, front Draw-Tite receiver, rear Draw-Tite class V receiver, BFG 285/75R16 AT KO's
Thanks Steve that is what I was wondering about.
One other question I am not familiar with silicone grease what and were do you pick this up?
Paul
[This message has been edited by Flatlander (edited 08-25-2000). ]
Flatlander, I've used anti-seize lube on my Dads brakes. (1990 dodge diesel) Just put it on the surfaces that mate between the caliper and it's mount. I also put a little on any bolts, for easy disassembly at a later date. HTH
98 Quad cab 4X4 2500 12 valve,5 speed,3. 54 rears, 8' bed. Boost and egt gauges but basicly stock. 55,000 Mi as of 8/21/00.
NRA life member. High power/IDPA.
I have the same pull with mine. It is cured for a couple of months when I lube the slides with anti-sieze. I do the mudbogs with my truck and a fter every race I need to do the lube thing after the pressure washer.
Tom
Smoker
96 2500 4x4 nv4500 3:54 slt 3"body lift 2. 5" suspension by skyjacker 267/75/16 street tires 36/12. 5/16 swampers for mud silencer ring lost 5" pipe borla KN round style filter JRE stage 4 400hp JRE afc spring kit boost and pyro gauges 16 housing pump timed and 3000rpm limit now 4200
