lubrication
Serice Manuals
New TDR member/CTD owner
Don't forget the U-joint on the drive line!!:)
I guess maybe this depends on where the truck was made but not all came with drive line u-joint fittings in them. Mine did not. Maybe if they have been replaced, the newer ones might have them. From the factory, the only place equipped on my truck were in the steering knuckles / track bar. Original ball joints, no. Although I had one ball joint (lower driver side) replaced & the new one came with a fitting. Throttle jockey called it, crawl under & let your eyes count. The best way. Good luck. Mike
I am not able to find a greese fitting on my 07 front drive line, but I am instructed by a note under the hood to not forget to lube it.
