Lug Studs, dealer item only ?
Utillity setting for turn signals?
Silencing the door "Dinger" ?
A couple lug studs on my truck broke. Went to the only parts store that was open last night and they told me it's a dealer item only.
I know other people here have changed them.
Is that true, dealer only ?
Thanks,
Nick
I got a hold of Napa, they say they can get them for me for tomorrow. 6 bucks each, beats the 14 each that the dealer wanted.
The only thing you may find is that the "shoulder" isn't as long that protrudes through the hub...
I used a stud from the front unit bearing to replace one of the rear studs that got damaged by a tire shop. That was the only difference I noted and its been working fine for better than 50k.
I got mine from RockAuto.com as well, and got a 10% TDR discount!!!
Just curious, are you running aftermarket wheels? If so, have you removed the spur clip retaining washers on your factory studs?
--Eric
I'm running the stock steel wheels and I believe I left those retainers off when I changed rotors the last time. <!-- google_ad_section_end --> <!-- / message --><!-- sig -->
Hmmm... do you have a good feel on why the studs broke?
Do you use anti-sieze on the studs? What do you torque them to?
I broke several studs soon after I changed to aftermarket wheels. I didn't know that you had to remove the spur retainers for most aftermarket wheels. I also had always used anti-sieze on the lugs.
After removing the spur retainers and torqueing the lug nuts to 165 ft-lbs dry (no anti-sieze), I've not had any problems... and I've put my lugs through alot of abuse!
--Eric
It was me, I think I torqued them to my car wheel setting of like 100 ft lbs. 4 studs broke on one wheel. The rest of the wheels had loose lugs too, but no damage.
