2nd Gen Non-Engine/Transmission lukes link
2nd Gen Non-Engine/Transmission Block heater up in smoke
Has anyone used these on there truck? I am picking up an 2001 ram sat. (nice truck) I am sure the front end will need help like my trucks in the past! This product looks to be an option for the track bar "turd" set up that dodge run's on these trucks. Anyway it will be nice to be back in a diesel, Cummins rules.
I've Installed Three I Think But Be Careful There Are Two Different Track Bars And The Link Will Only Fit 1 Of Them. I Found Out The Hard Way. Measure The Diameter Of The Head And The Link Will Fit The Smaller Head Bar Oem And Napa I Think. The Moog Bar Has A Much Larger Head They Have A Fix For This But It Require Swapping Out Your Bar With Them They Thread The Head To Acept A Threraded Plug Better Set Up In My Opinion But A Lot More $$. Just Research A Little Before You But But A Good Fix.
I've used one on my Dodge as well as a couple of tractors. Work great. When they get a little loose, you just add a spacer (washer) or two to tighten back up.
