Afoulk;
I linked the tie rods, pitman arm, track bar, etc. - 5 in all - on my 2001. They fit on the tie rod ends without rubbing the backing plate or rim although the clearances are tight. It was easy enough that someone with little mechanical
ability (me) can do it. Good luck and wrench away.
4str
What do you mean by turning in the pinion nut? Is that the same as tightening the steering?
I know theres a difference in size between some of the different trackbar manufacturers. Is there any difference in tierod ends? Mines a Napa piece, dont' know who makes them for them. I just wanna make sure this thing is gonna work ok before I go grinding the cap off the tierod end.
