Engine/Transmission (1998.5 - 2002) Mag-Hytec and magnet
2nd Gen Non-Engine/Transmission A/C Fan motor relay issues
2nd Gen Non-Engine/Transmission Power Steering pump plug
A few years ago I changed out my trans. pan to the aluminum Mag-Hytec. I did not reinstall the factory magnet as it was not compatible with aluminum. I have given some thought about cutting a piece of sheet metal and using epoxy to hold the sheet metal for the magnet. Doing it this way would allow removal of the magnet for cleaning. Thoughts on this process ?. Any one recommend the epoxy to use that would hold up to the heat, fluid, and hold the sheet metal to the aluminum. First thought was JB Weld.
Dave
