Mag-Hytec install
How to make your Boost Controler
Gear Vendor vs. US Gear
Just ordered the Mag-Hytec diff cover and double deep transmission pan. Does the diff cover install on a 4X2 Dana 70 without any modifications?? (Is there enough room?)
It should fit, no problem, it will be about a half inch above the skid plate. Fine for the street, but be careful if you go offroading alot. I have yet to install mine.
EMD -
I believe he was asking about the read diff cover... . not the transmission pan.
beartrace -
I have a 4x4 so I can not answer your fitment question on the Maghytec Rear Diff cover. Let me take a peek in the archives see if there is anything.
Ok according to my research, a spacer is required on the Dana 80 4x2 trucks with a swaybar. I don't belive the Dana 70 requires one. Who did you order from? Did you tell them you had a 4x2 truck? A spacer is supposed to be included with the kit if ya require it.
What year and type of truck you have? Please list the particulars... ... .....
More info from beartrace
I ordered the mag-hytec diff cover from woodlawnrv.com @ $205.
I have a Y2K automatic. See signature below. I was hoping that I don't need the spacers. Thanks for any info you can provide.
I found the answer to my question in the Geno's catalog. The Dana 80 with factory-installed sway bar require spacers for the Mag-Hytec Diff cover and will be supplied. The Dana 70 fits with no problem.
I ordered Autometer qauges from Geno's ( EGT, Boost, transmission temp) and they could only ship the transmission temp. They are back ordered on other gauges. I called four other suppliers and all had the same story. It seems there is a run on Autometer qauges and they can not keep up with the demand. It will be two to four weeks before I see the other gauges. By the way, I ordered from Geno's two days ago and the transmission temp qauge, and A-piller arrived today. They have fantastic service.
