Hi,
I have a Mag-Hytec, AA 14-11. 5, rear differential cover on my '03, 3500 SWR, 4X4. I've been wondering about the added amount of gear lube it requires. So, I crawled under the truck and did some measuring. The level suggested with the Mag-Hytec is quite a bit higher than the level indicated for the stock rear-end cover.
There are two level marks on the dipstick that comes with the MH. The bottom mark is 7/8" higher than the bottom of the fill hole on the stock cover. I believe the stock DC recommended level should be 1/4" below the fill hole (+or- 1/4"). The top mark is 1-1/4" above the recommended fill level. The stock lube capacity is 7. 65 pints or a little under 4 qts. The MH recommends 6-8 qts.
The stock fill is level with the bottom of the axle tubes, outside diameter. It looks like none of the lube flows into the inside of the axle tubes, unless it is pumped in, somehow. I wonder how the outside wheel bearings get lubed?
With the MH recommended levels, the bottom level marking on the dipstick places the lube inside the bottom of the axle tubes. The top marking puts the level at the bottom of the axles, themselves. Seems like the bearings would be in a bath of gear oil all the time. It sounds better, to me. But, then I am not a mechanic and know little or nothing about rear axle lube requirements.
American Axle & Dodge must have a reason for wanting the lube level so low. I called MH, and they thought it may be because, if the bearings and seals aren't soaking in gear oil all the time, there is less likelyhood of them ever springing a leak during the warranty period. But, there's, also, less oil lubricating the bearings & gears.
I would appreciate any thoughts and suggestions from you guys with a lot of experience with axles and lubes.
When I bought the MH, I also bought 8 qts. of LE-607 gear oil. It's supposed to be an excellent gear oil but, it is not synthetic & I'm a little hesitant to use it, while the truck is still under warranty. Any thoughts about that would be appreciated, also.
Thanks for your help.
Joe F. (Buffalo)
Joe F. (Buffalo)
