Details here: TDR Privileges
It depends on how you determine what is full, if you want it to the same level as the stock cover it will take around 5 quarts, if you go by the dipstick that is in the cover it will take a lot more but will not be filled to the same level as the factory, it will be much higher. The dipstick is not matched to the factory fill level.
8 quarts measuring by the dipstick on the new cover. I used redline 75-90 with out any slip additive. It says not to use the anti-slip additive on the gears( it's not recommended)
