Mag Hytec transmission Pan Gasket
Banks Big hoss and auto transmission
Diesel Dynamics, great customer service.
Guys just quick Q. Where to get gasket for Mag Hytec transmission pan ? Is the OEM gasket same ? Pretty soon I'll change oil in my transmission, and want to have new in case old one can't be reused. Thanks.
M :cool:
Just use an OEM gasket. I would recommend not using the large reusable rubber one though, I would just use a standard gasket. be sure to check the bolts a few times after you tighten them as they tend to get loose.
Doug
When I get my transmission filter, a gasket comes in the box with it. I've changed the fluid 3 times I think, went fine every time. I do torque the bolts to specs and never had a leak. Old gasket comes off just fine, no tearing or scraping.
Bob Weis
