Mag hytec transmission pan
Plunk and Roll
stock transmission temp sensor question
I got a mag hytec double deep transmission pan and was wondering which gasket to use. The pan came with a cork type gasket, but factory is plastic with rubber molded insets. Can somebody who has one give me advise? Thanks in advance.
Tom
i used the one that came with the new pan. . no problems. . i
however i plan on using a mopar gsket on next filter change.
I have used the factory rubber molded gasket with the Mag - Hytec double deep pan on two different trucks. Both trucks have had no leaks and the rubber gasket is reusable for when you change filter and adjust front and rear bands.
