Well I finally did it. Replaced the factory transmission pan with a Mag Hytec 68rfe-a. It was a lot of fun, kinda, but not really. The first encounter was getting the old pan off.
I went to Tractor supply and bought a giant 6 gallon rubber pan to catch the fluid so I would not spill it on the carport driveway. Well when I got all the bolts of except a couple,
the rtv sealer just would not let go. My son was helping me by way of google and I followed one of the suggestions of using a razor blade to slice between the pan and rtv.
Dang sure was right, cause the pan dropped before I could catch it and I was wearing a good quart on my arm and a little on my face
. Next was getting the new pan on, not too bad. got it torqued down to specs and now up to the dipstick filler hole. Why, I asked myself, did they put the dipstick filler hole to where you need a certain type of funnel
with a flexible bend in the tube, which I did not have. So, My son and I put a small funnel and a larger funnel together to make a make shift gizmo. It worked fine, til it got bumped and came apart. I ended up going to Home Depot to buy a proper flex funnel, but all they had was a small transfer fluid hand pump. It worked out the best, without spilling a drop. At least I have the pan installed and a drain plug now, not to mention more fluid capacity.
