Mag-Hytec
Stock Speakers in a 98'QC
Wanted: "Banjo" Fittings, Fuel Lines, Lift Pump
For those who may want to know.
The Mac-Hytec Dana-80 cover is unreal. It is the best made, best fit, most direct instructions of any product I have ever bought for a vehicle. I have installed other products on my truck and have had to adjust for weeks to get them right. This was right the first time. No drips , no nothing. It worked just like the paper said. Am I excited? A little! Was it simple? Yes , but I'm still overjoyed.
What' next? The by-pass oil filter. It don't look so easy but hear goes.
Preston
96 3500 Black 5 speed turbo diesel, SLT, with US Gear overdrive, Rhino liner, Reese 15,000 lb. fifth wheel hitch, US Gear de-celarator exhaust brake, muffler elimination kit, Amsoil lub. , with other goodys on the way.
This is a candidate for the "Products" forum. I'm giving it a nice smooth glide across the electron sea to that forum.
Thanks for participating
Mark
I whole heartly agree!!! I just installed my Mag-Hytec Diff. cover for my Dana 70 and it to is outstanding.
No Drips, No Runs, No Errors!! #ad
A great product!
Sparky
1999 2500 SLT, QC, LB, 4x4, White, 4. 10 gears/Limited slip, Trailer/Suspension Package, Most Accessaries, Auto transmission, Westin SS Nerf Bars, Painless Wiring, Silencer Ring Missing, Mag-Hytec Diff. cover and more coming (I Hope)!!!
Next addition, Gauges... ...
Pull a 26', Tahoe TT (6000 lbs. ) and hardly know it's back there!
[This message has been edited by Sparky10 (edited 06-14-2000). ]
[This message has been edited by Sparky10 (edited 06-21-2000). ]
I asked the same thing...
The response was that there just wasn't enough room to fit one...
I wanted to do both front and rear at the same time. but it looks like a no-go.
I have seen a Dodge Crome cover that fits. . If that helps.
Larry
Be carefull about using a chrome diff cover, chrome insulated and will hold in heat. That's why Mag-Hytec uses an aluminum cover. It disperses heat and helps the rear end run cooler.
kevin
Amen on the Chromed heat! Polished, chrome serfaces don't have enough serface area to disipate heat. Keep the rough finished stock front cover, and paint it flat black to pull heat through the cover and into the air * * * *
kevin
Does anyone know if the Mag-Hytec Dana 70 cover will fit if I have the factory camper package rear sway bar installed?
Greg
Y2K Dodge Cummins QC 2500 SLT Laramie 4x4 Long Bed, 4. 10/Auto, Forest Green/Driftwood, 265x75R16 Michelin LTX, 6 speaker CD, Camper/Tow/Plow Packages, Westin Black Nerfs, Mopar bedliner, Ultra bright diamondplate toolbox, K&N Filtercharger.
http://www.rints.com/hammond for photos!
Not Bombed yet!
Hammong,
It will fit with no problem. Some models need to add spacers to the sway bars but not
yours. Roy at MAG-HYTEC has had machine shop
for many years and builds only quality stuff.
If you talk to him 877-786-6816 ask him how he likes the Active Suspension kit on his
truck.
mrbob
Anyone know if there is a front cover available for the 4x4's?
Per Roy at Mag-Hytec: "The front covers will be out around the beginning of the year. "
Yes, it will fit no problem. Only the 2WD 3500's require a spacer kit for the anti-swaybar.
Andy
Here's a copy of a email I sent to Hytec:
Will your Hytec cover fit the Dana 70 on my 1995 Dodge Ram 2500, 4x4, diesel, club cab, with a add on Hellwig rear sway bar? Thanks,
Reply from Hytec:
Hello;
I don't think it will fit. Hellwig has one of our covers and are planing on changing the sway bar so it will work I have not heard if they have it yet.
Thanks for the E-mail
Roy @ Mag-Hytec
If anyone has actually installed the Hytec on a Dana 70 with the Hellwig I would like to hear from them.
1995 2500 SLT Club 4x4, auto, 3. 54, 3300 pound Elkhorn slide in camper, AirLift air springs, Ricka dual wheel adapters, K&N, DC tow hooks, Rancho RS9000, Hellwig rear sway bar.
97,000 miles and counting.
Mag-Hytec is one of the best accessory firms around. Great products and Roy will give you lots of advice if you are in the LA area and stop by their shop in the SF Valley. Everyone I've recommended their products to has been happy as a grizzly bear with a week old moose kill.
Jim
I'll just further add to the kudos by saying that Mag-Hytec products are among the highest quality aftermarket automotive parts I have ever seen anywhere. They do a lot of aerospace machining work, and the quality shows. They are worth every penny.
'99 3500 QC 4x2, AT, 4. 10 LSD, camping/towing pkg. , Mag-Hytec rear cover & trans. pan, Auto Meter gages, K&N air filter, Mopar bed liner & mud flaps, Prime-Loc fuel filter relocation kit, Tekonsha Sentinel brake controller, Rancho step rails; Air Lift SD air springs
