I'm gonna be installing a Mag Hytech rear differential cover here shortly. I have the cover just waiting on the oil from Amsoil to arrive (prob doing it next weekend).
I just wanted to see if there was anything in the instructions that are not covered once I start the install. I thought that I had read in a previous post (cant find it now) that there are some numbers that are casted into the mateing surface of the Diff that need to be taken care of for the O-ring to seal corrcectly, but the instructions dont say anything about it. ANy idea's. If so, what should I use to fill them in?
ALso what will the new capacity be. I think I have read that it goes up to 6quarts? How much LSD additive should I put in? I know with the Amsoil many people do not add it without a prob, but mine over the past two years with Amsoil 75-140 has started to chatter a bit, especially when cold on a rear tight turn (like in a fastfood drive thru)
Also anything else I should look out for with the Diff open? ANything need to be re-torqued, etc?
Thanks for any info/advice you guys can provide. See sig for truck info. Truck has 57K total and about 25k since last diff oil change.
J-
J-
