Magnet to capture metal particles
Noisy (electronic) Ram vs CB and Cell???
Adjusting Parking Brake
Some of you fellows have stated, you have magnets on the oil pan or a magnetic plug.
What do you think about putting the magnets on the oil filter? Bad idea? It makes sense to remove as much of the metal circulating in the oil.
Bert
2001. 5,3500 QC 4x4, HO/6spd,limited slip,BD brake,60 gal Aero tank.
Bert,I think it's a good idea,I do it on my tractor hydraulic filters. You can buy premade magnets to go on your filters and pay too much or go to a shop that makes magnetic door signs and buy strip magnets for much less.
Thanks for the responses. This site has a wealth of information from people that have been there and done that.
Illflem, good point, I will go the least expensive way.
Wiredawg, I would be interested in finding out if the magnets on the filter keeps it off of the pan magnet. Fill us in as to the results. Probably collect in both places.
[This message has been edited by Happy Camper (edited 01-11-2001). ]
Griots Garage has one in catalog 105, but I can't find it on the web site. $12. 95.
Here is the web site link with contact information.
http://www.griotsgarage.com/
Shelby
2001. 5 2500 QC LB 4WD, ETH (Built 09-10-00), DEE, 3. 54 gears, Laramie SLT, Camper Special, Trailer Tow, Travel Convenience Group, Power Driver Seat, Alarm System, Remote Keyless Entry, Fog Lamps, Cab Clearance Lamps, HD Transfer Case, Bright White with a Gray Interior. Built 09-15-00, took delivery on 10-06-00, 3873 miles as of 01-04-01. Custom aluminum work body / flat bed. Coming soon: E-Brake and gauges.
I went to a sign shop and asked for some magnetic sign material, after explaining that I was going to put a strip around my oil filter and some on my oilpan, the guy said great idea and gave me some. He said that he would give it a try as well.
Did this 20,000 miles ago and still working great!!!
99 2500 QC SB 4x4 5sp 3. 54 LSD 285/75/16 Rancho 9000s A. R. E. Camper Shell etc. etc.
WIREDAWG! I was thinking you had the magnetic oil pan plug and could check it easily. (sorry about having my head on backwards).
One thing that I always do on my trucks is take an old stereo magnet and let it stick to the oil pan... . no problem with clearance with my present 4x4... . a lot stronger magnetic pull than anything else I've tried in the past. I just pull it off when changing the oil (hot) and the shavings just flow right out (hopefully not too many of them there in the first place).
'99 SLT REGULAR CAB, 5-SPD. , 3. 54 L/S, CARPET DELETE.
Duckhunter,What I found putting a magnet on the bottom of the oilpan is that the pan becomes magnetic and doesn't release the partials,if there are any. You can check if this is happening by placing some metal grindings or even dirt in the area on the outside where the magnet was and seeing if they stick. It's probably no big deal anyway, I'd rather have the metal partials stuck in the bottom of the pan than circulating with the oil. Having the magnet on the filter is nice because they get thrown away with the filter,you know they're gone.
I've also wondered if using magnets effects oil analysis.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(work truck)
95 3500,5 speed 3:54,Driftwood,Banks&Psycotty,34,000 GCVW apple and tractor hauler(works harder truck)
Magnets will have zero effect on oil analysis and no negative effect on the oil. There is nothing in the oil that is 'magnetic'.
I question the effectiveness of using magnetic sign material - just not a strong enough magnet to work on the other side of the oil pan or oil filter. Just my personal opinion.
I use a purpose built unit from One Eye Industries out of Canada called 'The Bear Claw'. Very strong focused magnets on the oil filter.
Redram,
I like the idea of the Bear Claw oil filter magnet. Their website is not very helpful as to model number for our trucks. Do you know what number would apply to a '95?
Thanks
'95 2500 CC, SLT, LB 2WD, auto 3. 55, 70,000--Westech gauges in Autometer pod, Prime-loc, Brite box, Back-off Box, Line X, Flowmaster muffler, Borgeson steering shaft, Geno's Crankcase Breather/Vent Tube Catch-All
