Main injector line leak from pump to rail
Need Help With CR injector Diagnosis
Fca. Plug it in.... Unplug.. Plug..
So my main injector line began leaking on my 05'. While removing i noticed the pump itself was very loose, upon further inspection I found 2 of the 3 studs missing and the 3rd stud was still there but no longer had a nut on it. Is this a common problem? I replaced the studs with bolts and lock washers, it was all i could get a hold of on short notice. So basically the only thing holding the pump on was the injector line so i understand why it failed, but why would the studs come out?
I been fighting this same battle for about 6 or 8 months. After going thru 4 of the lines you're talking about it can tell you that it's about $52 from cummins. Easy to replace. As far as the stud/bolt issue. If you figure it out let me know. I'm betting a new timin cover is what it will take.
Fuel leak somewhere at the CP3 pump / found the high pressure connector line @ the pump that feeds the rail was leaking /tried to tighten the retainer nut and noticed the entire pump housing was moving/ not happy / had replaced this line 2 years ago, this is basically a new line/ WTH/ checked to see if the CP3 mounting bolts were loose... and there were none /what...really/ CP3 was replaced in 2014 by an inde shop locally /did he torque the mounting bolts / were they even installed? IDK /this may be the reason why I had to replace the high pressure feed line 2 years ago, who knows/ went to the local hardware store and sourced some mount bolts 8x1.25mm 1 3/4"L /put locktite on threads and hope they hold/ was able to get truck fired back up / still need to replace the high pressure feed line /Having a blast working outside in this wonderful NE weather/ Any input would B greatly appreciated/TIA
