Just a "heads up!", guys. After buying 2 new batteries 2 winters ago (to replace originals), I decided to try and prevent a premature death for them. About a month ago I opened up the cell caps for each battery and found that every cell was low; one was even showing the plate. I probably put about a quart of distilled water into each battery to fill them up. The "eye" immediately went dark instead of the usual green for full charge. So the acid mix was weak at first. The batteries would still crank strong, even with low acid level; and they cranked strong after the fill-up. After about a day of running the truck, the green eye returned and there hasn't been a hint of a problem. So the moral of the story is: don't buy the "maintenance-free" garbage that the battery makers are peddling. Drift back in time to yesteryear when we checked the battery acid level regularly. This will be increasingly important as the weather turns cooler.
95 2500 SLT, clubcab, 2wd, longbed, a/t, 3. 54, 135K miles, "all the usual refinements"
