Engine/Transmission (1998.5 - 2002) Maintenance instruction
2nd Gen Non-Engine/Transmission baby seats...
Engine/Transmission (1998.5 - 2002) Oil Canister
Is there any were on this site to find information on how to change the fuel filter and the brake fuild on my 2000 and 2002 4x4 quad cab 2500. If not were can I find it.
I'm not sure if you mean bleeding your brakes, but if you do then you do it just like any other disk brake system. I would get a niffty brake bleeder kit at an auto supply store(less than $15) and while you are there you should probley get a haynes manuel also($20-$30). It won't be real detailed, but good enough to do general maintenance. Here is a good website... http://www.dodgeram.org/tech/repair/Brakes/beeding.htm
As for the fuel filter
http://www.dodgeram.org/tech/dsl/filter/00fuel_filter.htm
and just make sure you don't get to much air in the line. It will make it hard to start.
