This is meant to be light, yet true to our experiences. It will probably remind us all of some not so fun things. I've been thinking about this for a little while and will try to be short, leaving room for the rest of you all to elaborate.
Here goes in intervals of 3k (I purchased with 75k dumped all fluids and started fresh):
3000 miles - oil & filter change, check/adjust rear brakes, inspect belt & hoses and look for trans, 4X case, differential and fuel system leaks. Grease shafts and steering zerks. Check trans fluid/oil.
6000 miles - same as 3000 - including: change fuel filter, check rear axle for oil seal leaks, clean and re-sli-glide those wonderful front calipers and check 4X case oil level. Balance and rotate wheels/tires.
9000 miles - same as 3000 - including inspect shaft carrier bearing, front & rear pinions and universals for excessive play.
12000 miles - same as 6000 - except replace those wonderful calipers (thank god lifetime warranty Wagner's loaded with new pads)
15000 miles - same as 3000 - remove rear drums & shoes (bounces when braking under 35 to 20 mph) fit to each other by bending frame on shoes.
It's a viscous circle I'll stop and allow someone else to elaborate I'm at 114k now have followed above and performed valve adjustment @ 100k. it's about time to re-fit the rear brakes and drums again - most recently replaced 3rd set of calipers - under lifetime warranty.
