Details here: TDR Privileges
Hey I am doing the 15,000 mile oil change and plan to change the axle fluid in the front and back but the only hole I can find is the fill/inspection hole, how do you drain the axle fluid? Thanks, Jay
You need to pull the covers off. Just make sure it is clean when you reinstall and the gasket should be good to reuse. I am not sure of the exact torque, might want to look that up in your manual.
