I am on the road and have had a major electrical problem. I was winching my race car on the trailer when the winch just quit. The truck was running with the marker lights on. When I looked for the problem, the marker lights were VERY dim, the oil pressure and temperature gauge were pegged high and one headlight was burning very dimly (even after the light switch was turned off). I made it to my destination with no lights working, and every time I hit the brakes the voltage gauge dropped to zero. I am about to go see if I burned up a headlight switch (again), but when that has happened in the past, it didn't do anything to the other systems in the truck. I tried to roll up the power windows, but they moved about 1/2" and stopped. It looks like the battery is dead, but the truck cranks right up and runs fine. The truck is a 90 D350 2wd, 85K, no drivetrain or electrical mods. Also, the fuses look good, but the a/c blower doesn't work now either. As a footnote, the winch was wired to the battery directly, so I feel this was a coincidence. Any help would be greatly appreciated!
Jim
Jim
