I have discovered a major oil leak coming from the drivers side of engine on a 97 12v cummins. I was hoping that is was coming from the lift pump gasket or oil pressure sensor but it's not. The leak appears to be coming from what I can only describe as a dust cover attatched to the side of the engine below the head. There appears to be a gasket associated with this cover. My question is what is the function of this cover and if there is oil coming out from behind it do I have a terminal problem ie cracked block. The engine has 1,012,000 miles on it. The only thing I haven't done on it is rebuilding the bottom end ie it has a new head, turbo, injection pump and injectors. I can't find any information on what the function of the aforementioned cover is and why it could be leaking oil out of it.
