Engine/Transmission (1998.5 - 2002) Making a vp44 run idle only
Engine/Transmission (1998.5 - 2002) nv5600
2nd Gen Non-Engine/Transmission loose steering with new box
So I need to make a 24v run before I pull the engine it's a auction truck that caught fire and burned up the harness. I remember reading a tdr issue that said you could unplug the vp44 harness and run power and ground to certain pins in the back of the pump and it would idle only. It would be nice to hear this baby run before I pull it to make sure there's no funny noises.
I plan on powering the lift pump and jumping the starter to get it running so if anybody can through the pin numbers out it would really help.
Thanks,
Shane
vp44 power
Look on Blue Chip Diesel's website and you should find what you are looking for in the troubleshooting section.
By the way got it running sounded sweet would have been fun to giver some r's but idle told us everything we needed to know.
