OK guys,
I am about to replace my stock lift pump with a mallory 4140M... But, I want to wire the pump directly from an electrical source using some type of relay. This way I can ensure proper voltage to the pump. Now the question to all who have done this, what type relay did you use and where did you locate it? How do I wire into the OEM wiring harness (from the lift pump) to activate the new pump? What other problems can I expect to run into during installation?
I am not a wiring genius so please be complete and simple with your explanations
Thanks,
Doug S.
Thanks,
Doug S.
