Man, do I love my BrakeSmart
Brake smart Question
Are Kit Trailers still being made?
What a awesome controller. It is SOOOO much better then my old Voyager. The Graphite color was an exact match to the Agate interior too. :cool:
I installed the pressure sensor in about 10 minutes. Very simple. You do have to bleed the air from the brake line where you installed the sensor by cracking open the line at the sensor. I didn't need to install the hose on mine because the angle of the sensor was OK without it, so it only took 1 pump of the brake pedel to bleed it. If you install the hose, it might take two pumps. You do not want to attempt nor is there any need to bleed the lines at the brake cyclinders.
Pics at http://www.klenger.net/dodge/brakesmart/slide01.html
