Update on the ATS 3 piece header problem, Reliance Truck & Auto retorqued all 12 bolts. This time the two top rear bolts worked back out. The rear most hole had been buggered up so badly that my Angola, In wrench, Dave's Diesel had to chase it out and use a longer bolt to get any grip at all. This time I had them cross-drill all the bolts and safety wire them. Couldn't get to the two bottom center bolts with safety wire, but so far they haven't been involved in the backing out issue. They also removed the header gasket and went metal to metal. They have had better luck with no gasket. If this doesn't work it's that $75 thick gasket in my future. Found that the head gasket is seeping coolant left front edge, not bad enough to deal with at this time. Will decide if the metal to metal is working when I land again and have the head gasket replaced. 13 trailers and I had to stop for water pump, ABS sensor, aFe filter totally plugged from soot due to header bolts backing out. The biggest problem of all was an injector line had vibrated through, was actually dumping my 1. 50 a gal fuel down the engine. More than half them trailers 13 trips back and fourth over Sandstone Mtn, running on 5. Wondered why them Furds were able to catch me and it started downshifting more than usual. Still no body or stacks. The Saga continues. . .
Cheers,
Steve J.
