I was doing my annual battery terminal cleaning today. On the driver side positive terminal there is the main cable to the starter, the cable to the passenger side battery, the cable to the fuse block, and the two wires to the manifold heater relay. I was wondering if it would cause any problems if I moved the manifold heater wires to the other end of the cable to the fuse block and attach them there? It would make the battery connections easier to maintain. The short cable to the fuse block appears to be more than large enough to handle the amp load of the grid heaters.
