Manual Boost Controllers
Please Help!!!!!!!!!
Injector knock fixed - Still a little mad about findings...
kblranch
Has anyone tried using a manual boost controller (www.boostcontroller.com) instead of the bleeder boost elbow? I was thinking I might try this instead of the elbow that came with the Edge EZ. The boost controller is supposed to allow you to adjust the wastegate opening at what ever pressure you set it at. Piers recommended that I run around 36 pounds with the Bomberlite. Without the elbow I have hit 28 pounds at 914 degrees post turbo. I was thinking that the extra boost at 36 pounds might cool things down?
