I installed this lock up switch today and it works great. It is much better than just a switch as it locks up with the switch, but cancels with the brake input, and lets the PCM take over if it meets the normal criteria for lockup. I used mini relays, but it would work with any ISO relays. I would also like to add a pressure switch in the governor port that would prevent an accidental lock up when stopped, or kill the lockup below the pressure set of the switch. I added the LED so I would know when the TC is manually locked. When the PCM takes over, the LED goes out.
