Manual Swap Confusion
5.9, G56 pilot bearing number needed
Slapping noise coming out exhaust
Hi everybody, first post here.
I'll apologize in advance- this is going to be a LENGTHY post. But, if you're in the mood for a bit of a storytime/rant with some questions sprinkled in, today's your lucky day...
I have a 2004 5.9HO/48RE/4WD QCLB 3500 that I picked up dirt cheap as a spare shop truck years ago. Didn't think much of it at first, but over time, I really took a liking to it... Truck is nearly bone stock besides a MBRP exhaust, mild Smarty tune, and a leveling kit with 4th gen wheels and slightly bigger tires (34.6" OD).
Of course- 48RE problems right from the jump... However I managed to string the first one along with basic upgrades/bandaids for about 60K miles. Eventually, the infamous (forward?) drum snap ring failure took out my reverse. Trans was already pretty shot right from the beginning, so I'll call that a win...
My buddy ended up selling me an ALLEGEDLY GREAT "freshly rebuilt" 48RE out of a truck he was parting out. Before installing, I dropped the pan and installed my old upgraded valve body as well as a slightly higher stall single disc converter. The trans had WAY too much metal in the pan for my liking- I knew it wouldn't last long. Either way, I pushed on because my other truck was down at the time and I really needed this one on the road. Sure enough, as predicted, the turd lasted 1000 miles before it fully took a dump. Maybe a front pump failure, I don't know, don't care, (now I'm pissed) and I have no interest in going in to another automatic transmission ever again.
TIME FOR A MANUAL SWAP. (Every other vehicle I own is manual, might as well make this one fit in too, right?)
So, my buddy who sold me the second trans feels bad and "warrantys" me an "NV4500" from another parts truck he had. I go ahead and sell my two trans cores and some spare tcases to the local core guy. Hopefully with that cash I can offset the cost of this little project...
Finally we get around to pulling the trans out of the donor truck. WOW, THATS WEIRD- this "NV4500" says GETRAG on the side of it... It was at this point that I learned there was actually a whole other oddball trans that came before the NV4500 in the first gens. Oh, and I already sold off ALL my other parts. Uh oh...
OK so you guys probably see where this is going by now. "Some idiot is trying to put a turd G360 into a 3rd gen"... Well, let me give you my reasoning for why I want to see this project through:
-This G360 is actually very freshly rebuilt. I know they aren't the greatest, but the general consensus is that they are "strong enough for most things" and that adding an extra quart of lube over suggested capacity does help mitigate the heat issues.
-This is a spare truck that I don't want to spend an arm and a leg on. It's just a backup.
-Truck isn't crazy souped up/making a ton of power nor do I ever tow heavy with it. (Truck is unloaded 95% of the time. Most towing work I do with this truck is moving motorcycles on a 10 or 16ft trailer- no real weight there. I maybe tow 1-2 cars a year. That's about it.)
-If my measurements are correct, I will be able to use my original driveshafts on this swap which is a HUGE cost savings for me (remember- this is a spare truck, not my pride and joy).
-All my 48RE's are gone now, and I DO NOT want to go through the trouble of selling this and trying to find an NV4500/NV5600/G56.
Alright... So with that said, here's where I'm at. I have been in contact with the folks at longrangegear.com (seriously kind, helpful, knowledgeable people by the way) and I've learned much about some of the speed bumps I must overcome here.
1- I did not realize that early 1st gen block adapter plates were thinner than the late style (and supposedly have a different starter location). I wish it were as simple as bolting on a 1st gen adapter, but from what I have heard, the bolt pattern on the block is different for common rail motors. Can anyone confirm this? Nonetheless, I plan to take my existing 48RE plate and mill it down to the correct thickness, restore/re-tap all threaded holes, and hope it'll do. Curious if I'll need to run a starter spacer, though. I can't seem to find info on protrusion differences between 1st and 3rd gen flywheels. I do know that the ring gears/overall diameter are the same, though. *I think this'll work.*
2- As for the transfer case, from what I can deduce all should be fine so long as I swap the input gear in my NV271D to a 29 spline unit which seems to be cheap and readily available. I plan to use a tcase clocking ring to hopefully achieve the correct tcase drop. It *seems like* the original NP205 and my 271 share a common bolt pattern, although internet data on this is sketchy at best. Please let me know if you think I'm missing anything here.
3- Alright, THIS right here is my biggest issue by far... Of course, a 1st gen runs a passenger side front driveshaft. My 3rd gen does not. In most manual swap cases this does not matter. But, since these trucks use an external slave cylinder, and that fat ass bracket and slave are totally in the way of my front driveshaft... I have a problem. My initial plan to remedy this was to convert to an "internal slave cylinder" or some people call them hydraulic release bearings. I thought this was an ace in the hole HOWEVER the more I looked into it, the worse it got...
First and easiest plan was to make a bracket and adapt a Ford M5OD-R2 release bearing that was laying around my shop. As you can probably guess, no shot on that... But OK, makes sense, it's a much lighter duty transmission, no problem.
Second plan was to use a Viper T56 unit. No good.
Third plan was to adapt a GM NV4500 internal slave for the job (thanks to insight from the guys at Long Range Gear). Seemed easy enough until I started looking at detailed measurements- evidently these trash chevy's use a lighter duty NV with a 1/8" smaller input shaft... Part won't even slide on the shaft of the G360. If I were to throw it on the lathe and bore it out, I'd surely destroy it.
FOURTH plan was to pony up the cash and buy a fancy billet racing type slave cylinder. "Surely they'll have the specs and dimensions I need available!" Well, no, that is not the case... Looked at McLeod, Tilton, and a few others. None of them offer anything fat enough for this input shaft size and bearing face contact area. I did find some guy from Australia that was selling NV4500 hydraulic release bearings (NV4500 shares the same snout diameter as G360 at 1.750") at a WILDLY high price over $700 USD a pop. I was about ready to order it, however, upon further inspection the flat-face bearing is way too small for what a standard G360 clutch requires. Can't remember off the top of my head right now but from what I recall I need something that will work in the 3.200"-3.400" range.
FIFTH PLAN- OK FINE, I'll do it the hard way... I'll keep the external slave, but slice a hole in the bellhousing and move it to the opposite side. I don't see any issues with relocating the clutch fork pivot ball to the other side, nor fabricating a mount for the slave cylinder, however I have some questions about the hydraulics...
Of course, I'll be using a standard 3rd gen clutch master cylinder and OEM pedal box assembly (MC is 0.690" bore if I remember correctly). I feel like I should use a 3rd gen slave cylinder with this to maintain the correct hydraulic ratio (0.827" slave cylinder bore, please correct me if I'm wrong). Where things get a bit messy here is that I'm essentially trying to determine if a NV4500 hydraulic system (which uses a very different clutch fork setup) can properly actuate a G360 clutch fork. The main variable here is I have no idea of the differences in pedal linkage geometry/ratio between the two. I do have my G360 clutch fork to measure against but I guess what I'm really asking here is- does anyone know the actual stroke the slave cylinder is supposed to travel on these trucks? I guess in order to do this properly I need those specs for 1st and 3rd gen trucks... Sadly it seems like this measurement is not really a commonly published one. If that dimension is not obtainable, does anyone have slave->fulcrum->throwout measurements for a NV4500 clutch fork? As well as pedal ratio info for 1st vs 3rd gen trucks? I think I have enough data on my side to do the calculations on that... All I know is the NV forks are quite different from this Getrag one, and I must assume that the pedal assemblies work quite a bit different, as well.
If you've made it this far in the post, thanks for listening. Yeah, I've certainly worked myself into a bit of a hole here, but I am determined to see this dumb ass project through...
Any insight is greatly appreciated!!!
-Austin
Wow! I see no benefit, even if you are successful with your project. The first generation Cummins trucks came with a maximum of 180 hp, 400 lb/ft torque rating because they were limited by the input torque of the automatic transmission and the manual Getrag transmission..., and you want to turn a stock 305 hp, 555 lb/f at 1400 rpm engine into a 180 hp, 400 lb/ ft torque engine so you won't harm the transmission?
My choice would be either NV5600 or Mercedes G56 - a much easier conversion and a great match to stock engine power and torque of your 2004 truck, and you get close ratio gears to boot.
- John
Anything smaller then an NV5600 will be ripped to pieces from this engine even in factory form. It has almost double the Power then a first Gen.
But I sure that isn't news to you.
There is reason why Ram upgraded the transmission with every new engine generation until they've run out on available manual transmissions to keep up.
Without a doubt, the sensible thing to do would be "just go get the right one that bolts in". Of course.
But at this point, I'm pretty much balls deep into this project and am determined to see it through. Honestly, I really just want to see if I can pull it off... I tend to do things "the hard way" far too often, but most of the time I enjoy a challenge.
I will agree that if I went the fancy billet TOB route yes, I'd be running the cost up quite a bit. But as of right now, that doesn't seem to be the move anyways so we're literally just talking about basic Rockauto hydraulic parts, a standard clutch kit, the pedal box assembly, a retune, and two transfer case parts... 90% of that I need regardless of what trans I use. I've looked at what good G360's go for as well as 4500 and G56. There is a SIGNIFICANT cost savings by going this route vs. the other two. (Also remember- original driveshaft lengths should work out in my favor with G360. Maybe my driveshaft shop overcharges, but last time I needed a simple rear shaft for a ZF swapped F250, it ran me nearly $800... Needing two of those plus a significantly more expensive NV or G56 totally blows the budget).
Sure, the 360 originally came behind a 180hp 12 valve. But I've seen enough run behind fairly turned up 12v's that I'm not so concerned about strength. The main mode of failure for these things seems to be high lube temps/possibly poor lubrication when towing heavy loads over large distances, which I do not do with this truck. I am also not really concerned about having a close ratio 6speed for this reason. As a matter of fact, since the truck has decent power and is damn near ALWAYS unloaded, I suspect the wider ratios of the 5spd will actually be a bit nicer to drive- we shall see.
Having driven 5 speed and 6 speed CTD’s there is a reason 5 speeds were phased out long before the 6’s. Empty or loaded.
Just because you can do something doesn’t mean you should do something.
We gathered you like the hard way based on the chronology of events posted, but that doesn’t mean you have to continue down the path.
Reading a little about G360 and NV4500 swaps it seems they are close enough to not need different length driveshafts, thou the NV4500 isn’t as strong as the NV5600/G56 options that should be behind the HO 5.9.
Have you already talked to Smarty about a manual transmission ECM file?
I called them a while ago and they made it sound like no big deal- pay them a few hundred bucks and they can do everything over the internet/mail. I have a bit of a hard time believing this but we shall see.
Just for ****s, I’ll play ball… What does a healthy NV4500 go for in YOUR areas? I’m in northern jersey where everything is wildly overpriced but always willing to take a decent drive for the right deal.
I’ve done quite a bit of research and it seems like a 4500 is at least +$1500 over a G360 around here. 5600 and G56 are far worse. But who knows, maybe I’m wrong…
Sounds like you have pretty mad skills as a junk yard fabricator and MacGyver type problem solver.
Please note that I say this with respect!!!
That said, "balls deep" and "doing things the hard way" instead of a "properly planned" way is a recipe for disappointment if not actual destruction.
My advice is to actually listen to the deep and cumulative experience of the members here.
If they say you are putting too much energy trying to shoehorn an undersized transmission behind the mighty Cummins ISB, you should definitely reconsider your plan...balls deep or not!!
Just my .02
Austin MacGyver, if there is a curse to having the skills etc that you have (which I admire), would it be that the ability to make something because one could gets tangled up with the practicality of it? If one spent this much time and money on something that could turn a profit, then maybe one could get a stage 1 48re transmission. If you got your "fabrication" done, what is your truck worth if you wanted to sell it compared to a "factory" truck? My stage 1 with a low stall converter is the best money I have spent on mine. Around town, it is "light on its feet" and towing, it keeps the revs down where the torque is until lockup. I agree with Big Papa, just maybe not as bluntly! LOL Mark
