Checked the transmisison fluid the other day for the first time. Noticed that the plug was only threaded into the transmisison about 2-3 threads. The rest of the plug was rusted and would not go in. Sprayed some penetrating fluid on the plug before removed it just in case it was already rusted hard and fast! Did not have any problem when removed it.
Should this plug be more flush? Have a '81 Chevy Luv, with the Diesel 2. 2L, and the plug on this transmission is flush tight. Should remove the plug, clean up the threads and then install it as far as it will go? Would this lead to possible interference with the gears in the transmission?
Is there a better method of changing the fluid than removing the most bottom bolt of the PTO cover and letting the fluid drain through the bolt hole? How long does it take to drain doing ti this way? Could the concept of the easy oil drain plug be applied here somehow?
