My Truck:
2009 – 2500 – 6. 7 – Manual Transmission – Completely Stock
I purchased my truck, brand new. Transmission was extremely tight until about 10,000 miles. I’m approaching 50,000 miles, and the transmission seems a little more loose than I’m comfortable with, having driven a 1995 Dodge Ram 1500 with a 316 engine as my first vehicle. This may prove to be a poor comparison to present day technology, and the fact that my previous truck was a gas burner and I now drive a diesel, but, I changed the transmission gear dope about every 50,000 miles (adding Lucas oil products after 150,000 miles). I sold the truck with 225,000+ miles on it, and the only transmission component I ever replaced was the clutch, 2 times.
I maintained a 50,000 mile transmission interval to check and change the transmission gear dope. So I referenced the owner’s manual of my 2009, and it lists ATF+4 as the operating fluid in present manual transmissions. Is this correct? Just want to be sure. If so, I know with automatic transmissions it is not recommended to change your transmission fluid, only add to it over the life of the vehicle. However, what is the recommended practice, since I have a manual transmission, that is using ATF+4 as the operating fluid? Change the fluid, or just add to it to maintain proper operating levels?
If, in fact, ATF+4 is the correct operating fluid, what is the viscosity comparison to 80W gear dope? If the viscosity of ATF+4 is less than 80W gear dope, could this contribute to the “loose” feeling that I am experiencing?
Thanks for all your input.
