I have had a problem with the truck bucking severly when you get hard into the throttle. I had mostly blamed it on a leaky sump, but when I last looked, that problem has been solved. The problem was
consistantly bad in cold weather and had all but gone away during summer. That is, until today on our first really cool morning in a while.
It threw lots of codes this time:
P0217 engine overtemp condition
P0230 fuel pump relay control circuit malfunct.
P0234 Engine over boost condition
P1689 no comm betweem ECM and IP
P1693Turbo charge control circuit malf.
Lift pump pressure never dropped, 13-15 psi the whole time it bucked.
RPM never dropped, it held steady at 2000 psi.
Although I have had a similar problem before, no turbo codes were ever included in the list.
I had an engine overtemp one time this summer, if it generated a code when that happened, it never turned on the light and was not cleared so that may be the one listed.
Could this be a PCM, ECM type issue? Maybe losing contact at the connector?
Thanks Gary
Thanks Gary
